Unit-Substation Transformers Efficiency
Does anyone has a graph showing the efficiency vs. loading for unit-substation transformers rated 1500-2500 kVA? In double-ended unit-substations these trafnsformers are usually loaded at 50%, and I am interested in seeing what penalty one pays for this.
RE: Unit-Substation Transformers Efficiency
Click on the above download within this link: http://
Scott Peterson
Training Manager
Power Plus Engineering
www.epowerplus.com
So with two transformer at 50% load versus one at 100% load, the load losses are reduced, but the core losses double.
no-load(iron), and load (copper) losses are equal. I want to know where that point is? Is it at 100%, 90%, 50% or what?
As an estimation a 2.5 MVA 11/0.433kV transformer will have approximately 2.8 kW no-load loss & 21 kW load loss.
Assuming these figues the maximum efficiency will be approximately 99.4% at unity power factor and will be obtained between 30% and 50% loading.
To be honest there is only a small a variation in efficiency over a wide loading. Between 10% and 100% load the efficiency variation approximately 98.8% to 99.4%
You should also note that the power factor of the load will also reduce the efficiency.
Maybe you should also consider the loss capitalisation costs to help you decide at what sort of level to operate your transformer at.
Also, check out this Guide for the Evaluation of Large Power Transformer Losses
http://www.usda.gov/rus/regs/bulls/1724e301.pdf.
I hope this help.
There is somebody with me about this?
I think IEEE requires that all parasitic loads, such as cooling fans and pumps be included in the input power, while IEC does not include these. But this difference has nothing to do with the subject at hand.
The graph above (Good graph Cuky) shows the effeciency well, at very light loads the no-load losses (iron) bring down the effeciency drastically.
The load losses are I2R losses therefore load dependant, iron losses are considered constant losses and are typically 0.5%.
For a 2.5MVA transformer, you could expect thye manufacturer to quote load losses of 25-28kW at 75C
You dont mention the transformer type, if you have an indoor compact substation with AN/AF cast resin transformers then you could load the transformers up to 70% of their nominal rating, that way you can support the full substation load from one transformer by force cooling the unit, otherwise if you have ONAN or AN type without forced cooling then you can load to 50% as you noted.
Thanks for the sanity check. However,the simplified formula gives sufficient accurate values for practical purposes.
For instance, in the example above for loading factor range up to full load and PF=1, the worst deviation between the two formulas is less than 2x10-5%.
Therefore, the term n2Psc can be neglected.
NOTE: If an accurate formula is required, the efficiency may be calculate with more precision as follow:
n= {1 - (Poc +n^2Psc)/[n.S.PF(1-Uφ/100)+Poc+n^2.Psc]}100%
Where: Uφ = The voltage regulation determined as the difference between the rated voltage of a winding and the voltage which occurs at particular values of load and power factor when rated voltage is applied to the other winding or windings.
