Remove formatting from Mtext
I've just copied in a whole load of manhole drawings from somebody elses drawing - old company / new company - only to discover that when I change the text style the formatting within the text remains. Its easy enough to open the text box and control all and control space and enter but this takes too long and I expect the problem to crop up again later.
Is there a solution, routine I guess, which will remove formatting from all mtext entities? Cheers.
RE: Remove formatting from Mtext
It may be worth a try to see if it converts the
group to single text.
