Mounting Pulley to Shaft
Can anyone point me towards the best way to mount a pulley to a shaft. I was originaly planning on press fitting the pulley, however my current one piece bracket will not allow this. The system will be used to control position so I can not have alot of slop in the rotational direction (will a keway still work). The torque values are low as well as the rotational speed.
RE: Mounting Pulley to Shaft
