shelling an object
shelling an object
shelling an object
How do I shell an object and have one face open?
RE: shelling an object
Build a smaller object within, from the common face, and subtract it.
Mike Halloran
Pembroke Pines, FL, USA
Hi bearisle,
Use the Solidedit command-> Body option then the Shell option - follow the prompts.
HTH
Todd
Thanks Carpenter...I had figured it out....I was doing exactly as you described, but was not selecting the face properly when removing it (I was selecting a corner which removed 2 faces).
