Writing to Attributes
Dear Folks;
Is it possible to write text fields to exiting attributes in a bill of material line item block ?
I have old bills of material which I would like to write into new bills of material which use blocks with attributes for each line item.
Best Regards
Adrian Dunevein
www.aaadrafting.com
RE: Writing to Attributes
It is possible but not inherently in AutoCAD. You can write LISP or VB routines to do it.
"Everybody is ignorant, only on different subjects." — Will Rogers
Here'e a quick and dirty way to do what you want. Works on a single text entry and attribute.
(defun C:XferTextToAtt (/ ATT SS1 SS2 TXT)
  (princ "Select Text:")
  (setq SS1 (ssget ":S" '((0 . "TEXT")))) ;Get text entity
  (setq TXT (cdr (assoc 1 (entget (ssname SS1 0)))));Return text field of text
                    ;(princ "Select Block Att To Transfer To:")
  (setq    ATT (entget
          (car (nentsel "\nSelect Attribute To Transfer To: "))
  (setq ATT (subst (cons 1 TXT) (assoc 1 ATT) ATT))
  (entmod ATT)
  (command "_REGEN")
Thanks Borgunit;
That code does exactly what I wanted !
Best Regards
Adrian Dunevein
Made a little change to include MTEXT...
  (setq SS1 (ssget ":S" '((-4 . "<OR")(0 . "TEXT")(0 . "MTEXT")(-4 . "OR>")))) ;Get text entity
  (setq    ATT (entget(car(nentsel "\nSelect Attribute To Transfer To: "))))
  (entmod ATT)
  (command "_REGEN")
Borgunit
Smokin !
You read my mind
Adrian
