type of pump to be use as fire pump
hi
what is the advantage of using a horizontal split casing pump as a fire pump for sprinklers instead of an end-suction centrifugal?
RE: type of pump to be use as fire pump
Naresuan University
Phitsanulok
Thailand
I'm thinking it is driven by flow and pressure demand only...in that end suctions efficiencies and therefore availability top out at flows below what split case allow. Lower flow (less than 2500 GPM) end suction might be better choice. Higher flow (more than 2000 GPM and upwards of 10,000) split case is the best option (and typically the only option).
I highly recommend going to a web sight such as the goulds site below, registering with their pump selection system (PSS), and trying some pump styles...model 3196 versus say model 3410.
http://www.gouldspumps.com/pss.html
If flow is where the two styles overlap in performance, it will just be a maintenance preference decision.
Stew
Naresuan University
Phitsanulok
Thailand
H Split pumps normally have a "flat curve" aroud its BEP, so its easy to comply the Fire Pump Code requirement to give 150% of its nominal Flow with a lowering of 35% of its nominal Head. However, some End suction Pumps may comply this spec. You just need to check if the pump is actually rated as a Fire Pump and so recognized for UL or similar.
However, if agreed with the Fire Dept Authority, you could select suitable pump of any type for the system.
Hovever, if the insurance underwriter stipulates a specific standard for the pump to meet - then maybe you are dictated to a particular pump style, but this is a complete new story.
Naresuan University
Phitsanulok
Thailand
Split case pumps are better performing, longer lasting and easier to service. They unlike end suction have bearings on both sides of the rotating element and dont have the problem of deflection. Their downside is that they are big and need more room.
Naresuan University
Phitsanulok
Thailand
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
ht
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
