Dynamic fire damper listing
I have been specifying Ruskin DIBD-2 fire dampers since I started my career
It has been brought to my attention that those dampers are not UL listed in horizontal installations for sizes larger than 24x24
http://database.ul.com/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html?name=EMME.R5531&ccnshorttitle=Dampers+for+Fire+Barrier+and+Smoke+Applications&objid=1075829623&cfgid=1073741824&version=versionless&parent_id=1073986213&sequence=1
Apparently this is the same for Prefco, Nailer, etc
What have you been specifying?
RE: Dynamic fire damper listing
same issue with nca ....
http://database.ul.com/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html?name=EMME.R10315&ccnshorttitle=Dampers+for+Fire+Barrier+and+Smoke+Applications&objid=1076128023&cfgid=1073741824&version=versionless&parent_id=1073986213&sequence=1
It appears that only the 3V multi-blade dampers are UL listed ...... same as Ruskin
Use the multiple damper installation for larger openings.  The openings can go up to 72x96.
Are multiple dampers UL listed?
The UL listing includes for installation of single or multiple dampers.  The dampers would be interconnected such that a single fusible link activates them all.
the maximum size for a dynamically rated curtain type fire damper is 48x36 in the horizontal position ..... this is the maximum size UL will test for that application
else you have to go to a static rated curtain damper or a fire/smoke damper
one has to look at the free area and static pressure drop due to elbows, etc
i will post again when i get all the info
