Water-based Heat Transfer in Closed System
In a uniform (3 1/2 foot height) 32 gallon, closed hot water tank where 1/4 of the water is at 170 degrees, and 3/4 is at 120 degrees, can final temp raise to 130 degrees in under 90 minutes?
It's been 5 years since physics in college and my memory for specific formulas in this discipline is rusty and my time, far too short!
Any help would be greatly appreciated...
RE: Water-based Heat Transfer in Closed System
Jendiggo
Just an aproximation but if you use a lumped capacity solution and assume a heat transfer of 600W/m2K, I recon it should take around 51 minutes
Of course if you want to get detailed you could probably fill up a set of conference papers on the subject
what is the insulation, how good is the mixing, what is the change of heat transfer properties as the bulk equalises etc..
Monaco8774
Yes!  You've made my day, and it's still before 9!
Thank you so much for confirming my late-night findings.  Although it does peak my curiousity, I'll leave you to write the conference papers on this one.  Thanks again, I really appreciate your help, and the time you put into it.
