Low temp application for Incoloy 800
Will Incoloy 800 have any problem operating in -100 deg. F inside of a pressure vessel designed for -265 deg. F? The electric heater inside of a liquid blow down tank has an Incoloy 800 sheath.
RE: Low temp application for Incoloy 800
Yes, the Incoloy 800 sheath material should be acceptable for use at this service temperature.
