Old Program
Old Program
Has anyone ever used a program called Analytix? Is there a newer program that will replace this old dinosaur?
Jeff
Jeff
Modern product development is complicated. With streams of data pouring in that inform how...
Download NowINTELLIGENT WORK FORUMS
RE: Old Program
http://www.saltire.com/download.html
RE: Old Program
RE: Old Program
Both should be available from www.msc.com
N4D is based on Working Model 3d which was gob-smackingly good, and for which there was a 5 body demo which was rather useful.
Alternatvely take a big step back in usability and look at freecad from www.askoh.com
What sort of problem are you trying to analyse?
Cheers
Greg Locock
RE: Old Program
It does cams, and any 2D linkages, (as the name suggests I guess) etc, and calculates forces and torques one you edit thee parts for mass, radius of gyration etc. You can drop in gears also if you want. I've used it a lot so if you need any help...
Cheers Solider
