SW2001 Installation - VBAI60 ERROR
Hi guys,
during the installation of SOLIDWORKS2001 I get a VBAI60 error.
Really I´ve no cloud what it means. It would be verry kind if there is anybody who can help me to solve the problem.
More information about the problem:
I`m using an:
Intel Pentium II 450
WIN2000
512MB RAM
Creative RIVA TNT II ULTRA 32MB
The prezise error message is: VBAI60 Init fail: 536870914
THX
Frank
I`m using an:
WIN2000
512MB RAM
THX
Frank
RE: SW2001 Installation - VBAI60 ERROR
Crashj 'sunny and cloudless here too' Johnson
I did it in the way like SnowCrash mentioned and it is still the same problem, (see symak).
Would be nice if anyone has a solution.
THX
Frank
Just guesing ...
Jack
Crashj 'sometimes SW sits and thinks and sometimes it just sits' Johnson
I tried to install SolidWorks 2001 and SolidWorks 2001Plus and in both installations I do get the message VBAI160 Init fail:536870914.
If anybody find a solution to this problem, please let me know.
pierreallard@sympatico.ca
Solidworks 2000 is not supported for WinXP.
WinXP support starts at SW2001 SP5.
If SW was there before you upgraded to WinXp (for whatever reason that was)you would never see the warnings.
I installed 2001 at home on WinXp and had the incompatability warning until I also installed the service paks. SW2001 SP13 works great on WinXP in my case.
I solved it when I put the changed default language in the control panel regional settings back to English US ...
In the VBA directory is only the vba6.msi. But this one is only US english OS. If you use a different language OS the installer tries to start a different vba60xx.msi. For example the spain version is called vba60es.msi (es for espania). Just make a copy of the vba60.msi in the same directory and rename ist to your language.
Here is the list of some languages and the needed filenames:
-Spain vba60es.msi
-Germany vba60de.msi
-Japan vba60jp.msi
-France vba60fr.msi
... and so on
How do I know this... There is one file in the setup which calls those files. If you look through the files (searching for string vba60) you will find all language codes...
So long
It worked!!!
Ciro
for example in spanish you rename the vba.msi to vbaes.msi and (after installing Solidworks) rename the subdirectories. Get the patches (sw2001*.exe, just find them)
Ciro
This particular problem should have been answered a long time ago by SW themselves.
BBJT CSWP
thak you very much, you dont know how hard i´ve tried to resolve this!!!thanks again
Gracias, BLUB eres un genio, no sabes como he tratado de solucionar este problema, estoy muy agradecido.
.....el problema del vbai60 error se ha solucionado.....
