Weldment Ballons
Weldment Ballons
Weldment Ballons
2 part question....
 Is there a way to specify the weldment balloons size? I also need to change the 1,2,3 format in the weldment balloons to A,B,C?
RE: Weldment Ballons
I must be missing something, can you be a little more specific? Thanks
With a drawing open, go to Tools > Options Document Properties > Detailing/Balloons
Also when placing the Weldment Balloons, you are given the opportunity to set the size in the dialogue box.
However, you cannot change from numeric format to alpha. You can only do that in the Revision table.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
