creating a flanged square to round....ex. ductwork
The only way I know of to create a square to round and be able to unfold it it the lofted bend command under sheet metal. the problem i'm having is getting a flange to come off of the square end of the square to round (on a 3 sided "half" of a square to round), so that it can be slid onto a square ductwork section. I need to be able to get the flat for the entire part. Is this possible (running soildworks 2005 currently) thanks for any help in advance i've been trying to figure this out for 2 days now.
RE: creating a flanged square to round....ex. ductwork
thread559-149512
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
SW06 added the ability to create a flange on a circular edge, so it may be possible in it.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
AutoCAD 05
FAQ559-1100
FAQ559-716
http:
chattlaser ... It can be modelled using regular SW functions, but cannot be created or flattened using the Sheet Metal functions. You will need to "cheat" by adding the tabs to a flattened layout config.
I think your right.
Chris
AutoCAD 05
FAQ559-1100
FAQ559-716
"CorBlimeyLimey (Mechanical) 14 Mar 06 14:03
I think he means something like this:-
http:
so it sounds like I would have to derive the flat with the tabs and insert sketch bends to get a formed view?
The "cheat" I mentioned consists of creating a separate config (not derived) of the part, then unsupressing the Flat-Pattern1 feature in the FM, and then adding the flanges. That config would then be used in a drawing view.
Another way is to add the flanges, as a sketch, in the drawing view itself.
