Catia V5R15 - Losing links from drawing to model ???
Hi All,
I am having a problem where my drafting is losing it's link to the model. When I try and replace the link, I see no links in the links dialog box. It seems to be fine for most of the time and then it suddenly decides to drop the links. It never really says anything about the links being missing, but you just can't see them or do updates etc.
Any thoughts????
Thanks, Gary.
Any thoughts????
Thanks, Gary.
RE: Catia V5R15 - Losing links from drawing to model ???
The only way that it should be able to "lose" a link, and not show you anything in the edit links dialog, is if you have isolated the view.
Losing links because of moved files and whatnot, is really not that uncommon. But if you don't have some sort of feedback - like link name, followed by "no found" - you have yourself an isolated view, and must recreate it.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
thanks, gary.
