Continious beam analysis spreadsheet
Finally, I took time and nailed it down. It's the easiest beam program ever, check it out on www.yakpol.net (it's marked new).
Continious beam analysis spreadsheetContinious beam analysis spreadsheet(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Continious beam analysis spreadsheet
To include vertical members will require to change force method to displacement method to solve statically undetermined structures. I have no intentions to complicate this spreadsheet, may include elastic supports, thats all. My main goal was: quick and easy.
Yakpol
Rotation is a slope, different words. Successive integrations method is good for textbook only, very cumbersome to code.
Did you use a technique other than integrations?
The integration is a general method, that you may use only after statical undeterminancy is solved. To solve it I used force method, as the easiest to program for cont. beams. Basic idea of the force method for beams is to release joints at the supports and to find restraining moments from the system of linear equations. For some reasons I could not find implementation of this mehtod specifically for cont. beams in the US published text books (not like I looked through all of them), so I just had to recall what I learned 20 years ago back in Russia.
Dik
thanks, Dik
