Fan efficiency too low?
We have calculated that ID fan efficiency for one of our scrubbers stands at around 50% or even lower, based on a 15 inH2O pressure difference between inlet and discharge, a 47,000 acfm flowrate, and the 250 HP fan motor running at full load. The scrubber´s fan is of the "wet" type, meaning that hot flue gases passing through the fan are already down to 60 degC and very humid after being washed down and scrubbed. Is this wet condition the cause of our low efficiency, or should we be able to achieve better efficiencies even under extremely wet gas conditions?
RE: Fan efficiency too low?
There is another possibility. If there is a large carry over of water droplets the fan will consume additional power "pumping" solid water. Check the operation of the scrubber to ensure that droplet carry over is minimal.
