trim imported curves
I have received an iges file, which contains curves exported from another cad system. I can open these in Solidworks without any problems but I need to trim these with a plane so I can find the length of the curve, which I will use in programming.
Is there a way to trim these curves with a plane? The imported curves appear as "ImportedCurve##" in feature tree.
Thanks.
Ahmet
RE: trim imported curves
Yes ... check out trim, surfaces in the index section of the SW Help files.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Thanks, but I want to trim the curve, not the surface. I created a flat surface, and want to trim the curve using this surface.
Any ideas?
Make a 3D sketch, copy the curve into the sketch using "Convert Entities", then trim as needed.  Measure result.
Thanks. Create 3D Sketch, Convert Entities, and Split Entities using intersection point, delete the rest and measure.
It works beautifully.
