save a copy of assembly model and drawing
Before I have save copies for assembly model and drawing, and everything was ok. right now when I save a copy for assembly model, change model name and copy, the drawing is not copied, but it works for part model and drawing. I don't know why?
I forgot what setting I changed? Anyone has idea?
RE: save a copy of assembly model and drawing
In config.pro change the attribute for RENAME_DRAWINGS_WITH_OBJECT to BOTH. And be sure that your assembly model and drawing model have the same name. If not it will not work.
-Hora
I suggest checking the FAQ section and search this forum before posting.  This question was asked about seven threads down last week.  Here is a FAQ I wrote because this question comes up once a month
Check this FAQ554-1122
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
