Welding 321 S/S Autogenous
I am having difficulty welding 321 S/S tube without any filler. I am consistantly being told it is due to a new low sulfur content. Also, that the Ti is bonding with another alloy which then becomes a lower eutectic point. The type of defect is porosity along the centerline of the weld. I believe it is due to cleanliness, and weld prep. Any advice would be appreciated!!
RE: Welding 321 S/S Autogenous
thanks
Another objection is that by foregoing the use of filler metal one eliminates the possibility to introduce ferrite forming elements in the weld to prevent hot cracking.
http://www.welding-advisers.com/
In your case, the cause of porosity in the seam weld is related to either a shielding gas problem or clealiness.
In line with metengr's comments when we first started autogenous welding (safe ending) of Hx tubes we actually used electropolishing techniques for cleaning in order to get a good weld.
How is the shape of the weld?
Is there any possible lubricant from the forming dies getting to the weld area.?
