Breaking Dimension Lines
I am trying to find a way to break my dimension lines. To clarify, when you have two dim lines that cross each other, you are supposed to cut one around the other so that each can be seen individually.
Has anyone figured out how to do that?
RE: Breaking Dimension Lines
This functionality has just become available in SW2001+. Just select the dimension, select break lines and the dimension crossing the original dimension.
Kevin
