Loft in SolidWorks
Loft in SolidWorks
Loft in SolidWorks
Does anyone know how to create a loft between this flange. The link has the SolidWorks project file and a AutoCAD image of the desired result.
http://www.unpluggedproductions.com/SolidWorks/
      -Thank you
         Stan
RE: Loft in SolidWorks
I'm not sitting at my computer with SolidWorks installed, but it looks like you could build the outer cylinder and then do an extrude cut with a draft angle using the profile that you have in AutoCAD.
Create the Rectangular Flange & Circular Boss as a solid, first.
Then use the Lofted Cut to create the hollow. Sketch profiles need to be created prior to using the Lofted Cut.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Thank you guys, it works. You have been very helpfull.
    -Stan
A star for you, CBL!  I'll never be in any "postmater of the week" running, but you generally have a shot...hope this one puts you over the top!
Garland
