Material scanning
Material scanning
Material scanning
Is there method for scanning wire while its moving that can accurately detect any change in size?
RE: Material scanning
Try the following link:
http://www.shape-tech.com/
Orbis size gauges are the products used by the steel industry for precision measurement of bar and wire rod size.
You can also try Laser mic. (that is a company)
We use them for non-contact tube od monitoring when we grind or polish.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thanks for the responses.
