Changing Configurations of a part in sub assy
Before I start I'm using Solidworks 2004 SP0.0 in case a fix has been found, but i'm sure its something i'm doing.
1. I've a simple part, 0.12"dia Steel rod of 3 different lengths (no problem with the Design Table).
2. This part is assembled to a sub-assy. When this sub-assy is open in its own window I can change the rod config's without any problem (rightclick and prop's).
3. When this sub-assy is assembled to the final assy and I try to change the rod config the window and thus the config options is faint. This is the same when both the assy is active, the sub-assy is active and also when the part is active.
I've been playing with this model for a while and can't work out why this is happening, can anyone help?
RE: Changing Configurations of a part in sub assy
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
But, as much as I know how to create Design Tables in a model i've had to revert to the help files to create them in assy's (sub-assy). I wonder if you could help also here.
1. The Rod file has three configs (-111, -117 & -123) all different lengths.
2. Ok, i can move between these configs in the sub-assy. But as far as I can see from the help files the component name should change in the FeatureManager.
i.e Rod<1>(-111) should change to Rod<2>(-117)
notice the instance number <x> changing
but mine is changing as follows
Rod<1>(-111) changes to Rod<1>(-117)
notice the <1> stays the same for either config.
When I enter the name $CONFIGURATION@Rod<1>(-111) into the design table it is not recognized and shows an error saying component name is not recognized.
Any pointers with this?
I've just noticed should there be a space between Rod<1> & (-111). ie, Rod<1> (-111) opposed to Rod<1>(-111) ?
By the way, in the feature tree, my nomenclature for parts does not have a space between the occurence number <1> and the config name. I guess it's not supposed to be that way except in the file title at the top of the tree.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
I thought I'd try making the sub-assy flexible in the top assy, this I can do but doesn't affect the problem I have.
If I change the configuration in the sub-assy and save, that change of config is updated in the top assy after a rebuild. Which would be expected i guess.
The problem I have is what $Configuration@xxx names to use in an Assy design table. As the names I am trying to use seem to be the ones that are shown in the FeatureManager window, but these names are not recognized by the Design Table.
If you have several rods in the sub-assy, they will be marked as instance<1> (the first one) or <2> (the second one), etc.
What you are telling the sub-assy to do is make instance<X> show whichever config at that position in that FM. If the instance number were to change, the DT would get very confused.
Just created the Design Table in the subassy and the penny definitely has dropped.
Thanks CorblimeyLimey and Theophilus for your help.
