Opening SW just brings me to Email Client
with SMTP:performance@solidworks.com In the send to field.
Anyone experienced this problem. nothing has been changed on the computer since i used SW yesterday.
SW 2006,
Windows xp pro.
SW 2006,
Windows xp pro.
RE: Opening SW just brings me to Email Client
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
it opens email client and if i A) send an emial to performance@solidworks.com it sends and then doesnt open SW. or if i cancel the emial it still doesnt open SW.
Otherwise, reboot and try again.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
its not a problem with solidworks still running.
If Theo's suggestion doesn't work, RMB on the SW shortcut & (under properties) make sure the "Start in" path is correct.
Failing that, a repair os re-install may necesssary. Check the FAQ section for specific advice.
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2006\SW Event Log
to zero.
thank you very much
JAVELIN is not getting me the information I need.
eng-tips is much better. im still waiting 6 hours later for them to figure this problem out. they are our support/dealer for SW haha
IJITS they are.
thnx
how about giving whichever of these suggestions that worked a star (bottom left corner of the post that was helpful -- it says "Thank _____ for this valuable post")? I know you aren't supposed to solicit stars, but since I didn't have a clue how to handle this, I'm not soliciting for myself. Does that make it legal?
It's kinda' like the piece of candy after achieving a certain weight loss...
Garland
UR THE MAN :P
I have one user whose computer continuously resets itself to enable performance e-mail, so I set him up with a REG file so he could reset the key above on his own.
1) help them help the next person with the same problem,
2) let them be able to pass on that info to SW for a permanent fix,
3) put them in your debt, so you might get better service next time.
A win-win situation all around.
