standards for rubber lined process vessels
Could somebody help me with from where i could find standards for rubber lined process vessels.
ag
ag
RE: standards for rubber lined process vessels
There is no ASME or ASTM standard for a rubber lined tanks and vessels.
Chemical companies typically develop 'guide specifications" for metallic tanks and vessels built to ASME Section VII, API 650 or API 620. These company standards address the mechanical integrity of the tank or vessel...... the rubber lining is not considered to add any strength, it is only there for corrosion protection.
Several companies offer information about thier rubber linings. Try
www.anchortank.qpg.com
www.berubber.qpg.com
www.blairrubber.com
www.utibuoys.com
Please keep us posted on what you find out....
Also, what specifically, is your application ? chemicals ?temperature, pressure etc ?
Good Luck !!!
MJC
