exporting text
exporting text
exporting text
Does anyone know how one can select several mtext boxes, and export their combined contents to a text file? specifically if I have a bom in autocad, and want to export it to a text file. Thanks.
RE: exporting text
You can double-click on the text, then highlight it in the editor and then paste it into something. Is this the kind of thing you wanted?
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: exporting text
Not really, I'm looking for an easy way to do that with multiple text boxes at once, like if I ahve a bom with 50 fields, I'd rather not individually select the contents of each field.
RE: exporting text
If the BOM was created in a Table, the Tableexport command will export to an excel file. If not, you could explode the mtext (don't save the file if you want to preserve the mtext) and use one of the many text export routines available. I could post one for you if you'd like.
____________________
Acad2005, Terramodel
RE: exporting text
I have a lisp routine.  It work for single line text, I'm not sure about mtext.
CODE
;***    TEXTOUT.LSP
;***    Written by Don J. Buschert (c) 1996
;    Email:    don.buschert@sait.ab.ca
;        buschert@spots.ab.ca
;    AutoCAD Page:    http://www.spots.ab.ca/~buschert/autocad/main.htm
;    Disclaimer:
;    Permission to use, copy, modify, and distribute this software
;    for any purpose and without fee is hereby granted, provided
;    that the above copyright notice appears in all copies and
;    that both that copyright notice and the limited warranty and
;    restricted rights notice below appear in all supporting
;    documentation.
;    THIS PROGRAM IS PROVIDED "AS IS" AND WITH ALL FAULTS.  THE AUTHOR
;    SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR
;    FITNESS FOR A PARTICULAR USE.  THE AUTHOR ALSO DOES NOT WARRANT THAT
;    THE OPERATION OF THE PROGRAM WILL BE UNINTERRUPTED OR ERROR FREE.
;    Version 1.1    06/20/97
;    Revised the (REMOVE_ELEM) function thanks to Reini Urban pointing out a
;    serious flaw in the original by C. Bertha.  Apparently if there were multiple
;    elements, the old version would add the element instead of removing it.
;    Version 1.0 May 15, 1995
;    Original program.
;    Outputs selected text to an ASCII file.  Sorts the text by the
;    Y value, so you can select by window or crossing, and the lines
;    in the ASCII file will be correct.  You must select text with a
;    rotation angle of 0.  Failing to do so may yield unpredictable
;    results.
;    Warning!  There is a bug in the program.  If you select text objects with y
;    values that are equal, TX2MTX will ignore them entirely.  Just be aware of
;    the text objects your are selecting.  I'll get around to fixing this
;    eventually...
(princ "\nInitial load, please wait...")
;***    Function TEXTOUT_SORT
;This functions sorts the text object selection set and returns it
;in order with the highest Y values at the beginning...
(defun TEXTOUT_SORT ( / )
  ;create dotted pair list of text Y insertions points and string
  (setq tout_indx 0);set the index
  (repeat (sslength tout_sst2);repeat for each text object
    (setq tout_enam (ssname tout_sst2 tout_indx));get object name
    (setq tout_strg (cdr (assoc '1 (entget tout_enam))));get string
    (setq tout_yval (caddr (assoc '10 (entget tout_enam))));get y value
    (setq tout_dtpr (cons tout_yval tout_strg));create dotted pair
    (if tout_dtpr_list ;if dotted pair list exists,
      (setq tout_dtpr_list (cons tout_dtpr tout_dtpr_list));then append
      (setq tout_dtpr_list (list tout_dtpr));else create it
    ;increase index
    (setq tout_indx (1+ tout_indx));set the index
  ;create list of y values
  (foreach n tout_dtpr_list ;for each item in the dotted pair list...
    (setq tout_yval (car n));get the y value
    (if tout_yval_list ;if the y value list exists,
      (setq tout_yval_list (cons tout_yval tout_yval_list));add
      (setq tout_yval_list (list tout_yval));else create
  ;sort the y value list
  (while (> (length tout_yval_list) 1);as long as more than 1 element...
    (setq tout_yval (apply 'MIN tout_yval_list));get the min Y value
    (if tout_yval_slis ;if the Y value sorted list exists,
      (setq tout_yval_slis (cons tout_yval tout_yval_slis));add
      (setq tout_yval_slis (list tout_yval));else create
    ;remove the y value from the y value list
    (setq tout_yval_list (remove_elem tout_yval tout_yval_list))
  ;add the last element to the sorted y value list
    (setq tout_yval_slis (cons (car tout_yval_list) tout_yval_slis));add
    (setq tout_yval_slis (list (car tout_yval_list)));else create
  ;create a string list of the text values based on the sorted Y value
  ;list
  (foreach n tout_yval_slis ;for each element in the sorted Y value list...
    (setq tout_text (cdr (assoc n tout_dtpr_list)));get the text string
    ;if text string list exists
    (if tout_text_list
      (setq tout_text_list (cons tout_text tout_text_list));add to list
      (setq tout_text_list (list tout_text));else create it.
  ;reverse the order of the text list
  (setq tout_text_list (reverse tout_text_list))
;Controls and executes program
(defun C:TEXTOUT ( /
   tout_coun        ;counter
   tout_filo        ;open'ed file
   tout_flag        ;flag.
   tout_fnam        ;ASCII file name
   tout_dtpr        ;dotted pair
   tout_dtpr_list     ;dotted pair list
   tout_enam        ;entity name
   tout_indx        ;index
   tout_sst1        ;initial selection set
   tout_sst2        ;text only selection set
   tout_strg        ;string
   tout_text        ;text string
   tout_text_list    ;text string list
   tout_yval        ;text Y value
   tout_yval_list    ;Y value list
   tout_yval_slis    ;Sorted Y value list
;Define error routine for this command
  (defun textout_error (s)
    (if (/= s "Function cancelled.");if ^c occurs...
      (princ (strcat "\nError: " s))
    (if olderr (setq *error* olderr))
    (princ)
  (setq olderr *error*)
  (setq *error* textout_error)
  ;select text
  (setq tout_sst1 (ssget))
  ;if objects selected...
  (if tout_sst1
    (progn
      ;create list of text objects only
      (setq tout_coun 0);set counter
      (setq tout_sst2 (ssadd))
      (repeat (sslength tout_sst1)
        ;get ename
        (setq tout_enam (ssname tout_sst1 tout_coun))
        ;test to see if entity is a text object
        (if (eq (cdr (assoc '0 (entget tout_enam))) "TEXT")
          ;check to see if text has rotation angle of 0
          (if (<= (cdr (assoc '50 (entget tout_enam))) 1.0)
            (setq tout_sst2 (ssadd tout_enam tout_sst2));add to selection
        (setq tout_coun (1+ tout_coun))
      (if tout_sst2
        (princ
          (strcat "\n" (itoa (sslength tout_sst2))
                  " text objects found, with horizontal rotation..."
      ;if tout_sst2 is empty, then clear it...
      (if (eq (sslength tout_sst2) 0)
        (setq tout_sst2 nil)
  ;if there were text objects selected, then
  ;get a name for the ascii file
  (if tout_sst2
    (setq tout_fnam (getfiled "TEXTOUT - ASCII Filename" "" "txt" 1))
  ;if a filename was selected
  (if tout_fnam
    (progn
      ;sort the selected text objects by Y value...
      (TEXTOUT_SORT)
      ;open the file for writing
      (setq tout_filo (open tout_fnam "w"))
      ;for each selected text object, write to the file
      (if tout_text_list
        (foreach n tout_text_list
          (write-line n tout_filo)
      ;close the file
      (close tout_filo )
      ;delete the seleted text
      (if (not tout_flag)(setq tout_flag "Yes" ))
      (initget "No Yes" )
      (setq tout_flag
        (getkword (strcat "\nErase selected text? Y/N <" tout_flag ">: "))
      (if (not tout_flag)
        (setq tout_flag "Yes")
      (if (eq tout_flag "Yes")
        (command ".ERASE" tout_sst2 "")
  (princ)
;Support functions
;***    REMOVE_ELEM
;This function removes an element from a list and return the list without
;the element.  This program was originally known as serge:remove, written
;by Serge Volkov, the winner of the great lisp puzzle contest in
;comp.cad.autocad 11.Oct.96.  Reini Urban calls it "elegant and fast".
(defun REMOVE_ELEM (what from)
  (apply 'append (subst nil (list what) (mapcar 'list from)))
(princ)
RE: exporting text
Thanks that works well, but doesn't accept mtext. Does anyone have a routine like that that does accept mtext, or a routine to convert mtext to regular text? Thanks again.
RE: exporting text
Just explode mtext to make it regular text.
