Road Profile - Vertical Curves
Knowing the location (station) and elevation of my High and Low Points on the centerline of a road, how can I calculate the station and elevation of PVI. The desired curve length is 50'.
RE: Road Profile - Vertical Curves
Yes, I can choose the entrance and exit grades.
Thanks for responding.
Do you know where can get the spreadsheet with the vertical curve equations?
Be careful RacV2, there are other variables to a proper vertical curve design (i.e. K-value, stop/sight/headlight distances, max gradebreaks between tangents, etc.).
Good luck,
H.
