license check
license check
license check
is there a way to see what module licenses i have?
RE: license check
Not sure if you are on UNIX, but if you are on a Windows Machine, try this:
START --> All Programs --> NX X.0 --> FLEXlm Tools --> License Options
When this comes up, highlight the bundle listed in the left column, and the available module licenses will be listed on the right hand side.
I hope that this helps!
Chris Cooper
Cleveland Golf / Never Compromise
www.clevelandgolf.com
www.nevercompromise.com
RE: license check
The NX license activity is logged to
 D:\Program Files\UGS\License Servers\UGNXFLEXlm\ugflexlm.log
 (you location may vary) on the license server host computer.
When a license is "taken" you will see an entry like
7:08:22 (uglmd) OUT: "STUDIO4DS_gateway" username@HOSTNAME
RE: license check
Another option would be to open your license file with Notepad or Wordpad (if on Windoze) and then you'll see everything you're licensed to be using.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: license check
what is the license file name that I'm looking for??
RE: license check
Look under the install folder of NX for the FlexLM folder. The file is most likely named license.dat.
Ben Loosli
Sr IS Technologist
L-3 Communications
