fire protection : air craft hangar
application: boieng 737-700 hangar, 4000m²
we are opting for a overhead foam water deluge sprinkler system. What additonal measurements are required, like hand hose systems and under ground (under wing systems)?
max demand: how is the max simultanous demand determined? all sprinklers simultanous OR what part thereoff?
thks
thks
RE: fire protection : air craft hangar
What type of under wing monitors should be used in aircraft hangars?
If no draft curtains is installed does it mean that we will have to make provision (pumps etc..) that all sprinklers could be in operation simultanously? (total flow 6.5 lpm *4000m²=26000lpm)
I know when the wing area exceed 279 m² it is a requirement.
But what about multiple air craft? ( for instance 1 B737-700, 1 learjet & 2 helicopters?)
Imprecise requirements are a fact of life for engineering and you can handle them in a number of ways. Is this for an airport, what have the exisiting hangars got? That would be a good indicator of what the owners, tenants, insurers and regulating authorities are expecting.
