DNC stips out first line of program
Hi all, we're using Edgecam's DNC system to send and recieve programs to our CNC machines.  My problem is it seem to always delete the very first line of any program each time it is used.
Normally not a problem so much, but if a program is sent back and forth a few times (edits, backups, etc) then it becomes a problem.  We nearly had a huge crash where it had deleted a G10 datum set line at the top of the program, but fortunatly the operator  caught it.
Any ideas on why it does this?
Excessive accuaracy is a sign of poor breeding. -Socrates.
RE: DNC stips out first line of program
Maybe the first line needs to be:
CODE
Not sure, but give it a try.
Actually, if you crete a program at the CNC, and then output it to a text file...you can then open the text file and see what the machine wants as the first (and probably last) line.
Ken
That's a useful hint, (sending back an empty file) but no.
Say for example I have this program:
%1000
(EXAMPLE PART)
(PROGRAMMED BY KNOBHEAD)
G10 etc etc
When I send it to the machine it will look like this:
%1000
G10 etc
If I then send it back to the PC
%1000
G10 etc
Weird eh?
It sounds like it is not recognizing the end of the first line (program number).  If you can't figure it out you could always put several (Delete this) lines in the program after the number and that will at least buy you a few free transfers without losing data.  It really seems like it must be a setting of some sort, program transfer always seems to have the oddest problmes and solutions.
%1000
(Delete this line)
(Delete this line)
(Delete this line)
(Delete this line)
(Delete this line)
(EXAMPLE PART)
G10 etc etc
Fill what's empty. Empty what's full. And scratch where it itches.
Sounds like a communication settings problem.
Check the baud and parity, stop bits, etc. on the machine and PC.
In some cases slowing down the baud rate will help.
ah ha, fixed it.. there was no <CR> (carriage return) marker for the program to look for when it sent it to the machine, so it was just stripped out - removing the first line.
