Nuclear Plant Piping
Hello all,
Does anybody know how many miles of pipe in an average nuclear plant? What is the cost of piping compare to other components? Do you know any references for that type of inforamtion.
An Nguyen
An Nguyen
RE: Nuclear Plant Piping
2) relatively the same, though piping is cheaper because there is less manufacturing cost
3) for item 2, I would try manufacturer's cataglogs.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
Actual pipe lengths and exact layout also depend on the specific plant. I can tell you first hand that the 688 class submarines each are a little different, even while maintaining almost identical operational characteristics.
