Listing multiple pline area w/out picking each one, just the areas
How do I list multiple pline areas w/out picking each one, just the areas, not the coordinates.
Remember, amateurs built the ark...professionals built the Titanic. -Steve
RE: Listing multiple pline area w/out picking each one, just the areas
Hi lha,
I'm afraid the area command only accepts one closed polyline per "object" option - how about a quick and dirty lisp or VB macro?
HTH
Todd
You can type "Area" then "Add" then "Object" and pick them.  Not sure if it has to be one at a time.  If so, a simple LISP will do it.
Here is a quickie:
(DEFUN C:TA (/ AreaSum)
  (setq AreaSum 0)
  (prompt "\nSelect all objects to count: ")
  (setq ss (ssget))
  (while (> (sslength ss) 0)
    (setq en (ssname ss 0))
    (setq ed (entget en))
    (command "area" "e" en)
    (setq AreaSum (+ AreaSum (getvar "area")))
    (ssdel en ss)
  (prompt (strcat "\nTotal area is: " (rtos AreaSum 2 3)))
 (princ)
