Where to select Published Element
May I ask a dumb question?
Once an element has been Published, does it matter whether it is selected in the "Published:" list, or selected directly in the tree?
(This is related to a question I'd had about being able to re-organize the display of the "Published" group - if it doesn't matter whether you select the element from under the "Published" group, or directly from the Tree, then being able to re-organize the "Published" group isn't important. But this is just a related issue to my question above...)
Thanks.
Thanks.
RE: Where to select Published Element
In the publication menu you can export the publications to a text file. open the text file in notepad and re-organize. Delete all your publications in Catia , import the publications from that text file. Now you can relink the publication by picking the publication in the menu and selecting the item that was orginally published. (nuisance I know) I did this to my seed parts and custom templates.
Derek
Abe: I suggest you set the Tools+Option to "only use published elements"
jackk - I'm on it. thanks! (that's a very nice feature to prevent update problems with contextual links...)
Derek
