I need some tree help.
I am working with a Catia Part File of a Die assembly from a customer and can see that each part of the assembly is located in the tree.
I can hide/unhide each part and switch between visable parts, but do not know how to have all parts visable at the same time. Can anyone please help me with this?
RE: I need some tree help.
forfun
Select from top level assembly. use selection mode / select all. then turn in show / no show.
You might need to do it twice in order to bring all PARTS in show.
I said PARTS, if Bodies are in noshow, you need to make your selection deeper (not only at product level).
But working at Product level the select all is good.
