How to use Hi set function of protection relay
Hi
I know that all of numerical relay have hi set function and I don't know how to use it.
I mean, under what condition it is used and how to select the right setting.
Or any web page, literature that I can look at it? I googled its use in the web and no satisfactory result.
RE: How to use Hi set function of protection relay
High set is a function found on some thermal (IDMT) relays or LV breakers and is typically used to provide an instantaneous trip function when a threshold current is exceeded. It reduces the reach of the thermal overcurrent curve at very high currents.
  I don't suffer from insanity. I enjoy it...
On the relay I have been seeing, they have a hi set different from instateneous and it can be timed.
What we normally do is to provide the IDMT with a higher time than the hi set and a lower current setting. As such the time of relay operation will be graded according to the level of the fault.
Thanks khadisa,
I should have said that the hi-set function can have a definite minimum time, whereas the true instantaneous setting is just that - instantaneous.
Use or non-use of the hi-set or instantaneous function depends on the application.  There isn't really a one size fits all answer.
BTW, the term "hi-set" has never really been used in the US.  We just call it "instantaneous" and if we add a time delay to it, we just live with that inconsistency or call it a "definite-time" function.
Dave
