Wet Ball Value or L.A. Abrasion Testing Alternatives
We have a client requesting a wet ball value (TXDOT TEST METHODS 116-E) or, as an alternative, an LA Abrasion Test. The problem is they don't have enough material to run either test. Are there any other tests out there that would yield similar information with a smaller sample size (6000 grams or less)?
Thanks in advance for any help.
RE: Wet Ball Value or L.A. Abrasion Testing Alternatives
www.geneq.com Can also contact them for 'info'.
