exposed duct through wall 45 degree angle
anyone ever penetrate a drywall soffit at a 45 degree angle in an exposed spiral duct application?  architect is looking for a detail of the penetration.
RE: exposed duct through wall 45 degree angle
The sheet rock people can precut an eliptical hole in a piece of sheetrock, slide over the duct stub.  It will require some coordination.
Otherwise put this note on the drawing:
BEAT TO FIT, PATCH TO MATCH.
Yes we have had a few instances on a project where the duct was installed as shown on the mechanical drawings penetrating a sheetrock wall partition exposed to view. (Not a fire rated wall!) We took some measurements of the actual instalation and fabricated escutcheons as required.
The penetration was typical of any other non fire rated penetration exposed to view.
rogzog
