literature for introduction to C programming
3
I am looking for a recommendation on reference material to start out with in learning (relearning) C programming. I only took 2-3 courses in it in college and would like to start with basic review and progress. Any books' recommendation would be great!
RE: literature for introduction to C programming
You could check this two books:
"C: The Complete Reference"
by Herbert Schildt
"C++: The Complete Reference, 4th Edition (Paperback)"
by Herbert Schildt
The last one describes both C and C++, but emphasizes the last one. Both books have descriptions and reviews on amazon.com
I only have the last one, which I think is a great book to have and very useful, but I am sure there are other good books as well.
There's one titles simply "ANSI C", but I don't have a copy near me to check on the author (as I'm sure there will be multiple books labeled similarly).  It had a yellow binding, if that helps narrow it down.  I found the book to not only explain the salient points of C in a clear way that was also very instructive, it continues to serve as a great reference 10+ years later...
Dan
Owner
http://www.Hi-TecDesigns.com
"The C Programming Language" ISBN 0131103628 by Brian Kernighan and Dennis Ritchie is excellent.
Good Luck,
Greg Hansen
The original is still the best!
"The C Programming Language" by Kernighan and Ritchie
is the way to go.
I suggest that you follow along with the examples in
the book and program them as you go.  Then try them
out and make them work.  Then "play" with them (modify)
and see what happens.  Then onto the next section.
  Cheers,
   Rich S.
Well, to start, why do you want to learn C now?  What plat are you developing on?  What applications for it are you looking at?  C++ mostly replaced C except for some things, like the Linux kernel.
For business type apps, which I work in, and which, from my observations, most of the jobs in the US are in, it is mostly C# (and other .net langs, like, ughhh, VB.NET) and java.
C is a very, very low level language.  I would place C about a level above asm.  Very few people do C aside from very specialized things like kernels and drivers.  C++ is a step above that, but C++ has it’s performance drawbacks for things like kernels and drivers.
I mostly do windows development.  I have not done a pure C commercial project since DOS.  C++ pops up on occasion.  Now, most of the game is C# and java.
"C++ mostly replaced C except for some things, like the Linux kernel."
"C is a very, very low level language.  I would place C about a level above asm.  Very few people do C aside from very specialized things like kernels and drivers."
With the above two statements, paul, I would venture to say you have your head stuck in the sand.  Ever tried to write an embedded app in C++?  I thought not, especially considering how many billions of embedded processors are out there running C/asm code on them.  A few embedded apps are written using C++, but C has the lion's share by far, along with numerous other languages.  To consider C barely a step above asm is ludicrous.
Dan - Owner
C++ is a requirement for gratuitous bloatware.  Never heard of a single microcontroller being stricken with it.
I would guess more C is written than anything else. Because I think there are more embedded systems writers than all other classes of software. I could be wrong though just a guess.
Keith Cress
C has always been the primary language in the domain of embedded systems and telecommunication. All micro-controller and micro-processor programming is done in C.
paulfrancis (Chemical),
C is probably the only language which can be used for both high and low level programming. U would be surprised at the number of telecom and gaming companies in the world (not just US) which code in C.
fuseshut (Electrical),
C is an extremely versatile and robust language and I am sure it will be around for many more years. My recommendations would be:
1) Programming in ANSI C - Prof. E. Balagurusamy
2) Let Us C                       - Yashavant Kanetkar
fuseshut;
Kernighan and Ritchie is THE de facto standard handbook for C.  They are the guys who brought it to life. It is the definitive authority.
Me? I find it not that great a book, a little to obscure for me.  I have gone thru many books on C but the very best I have found, and it's a great book to read, is... I forget.. I never could remember the name of any book only what's in it.  So when I get in to the office I will look at it and come back here with it. It is very clear with excellent examples and it's very logically and cleanly written. And it's funny to boot.  A good read.  I give it a 10 out of 10.  Now if I could only remember the name of it.. tisk, tisk, banghead
Keith Cress
These were both highly recommended to me when I thought I would need to program in C.
In the end, I was programming in Pascal. Another story.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I was given to understand that "Real Programmer's Don't Talk Pascal"... clown
That is what we like everyone to think. winky smile
Albert Einstein
Real programmers don't eat quiche - they eat Twinkies and Szechwaun food.
Albert Einstein
Loved the bit about wearing climbing boots in the computer room just in case an Alp suddenly appears... clown
And writing everything in FORTRAN  whilst having a sneaking regard for C...
Hiya-
As I remember it, it wasn't:
"I was given to understand that "Real Programmer's Don't Talk Pascal".."
Rather:
"Real prgrammers don't use lower case."
or
CODE
C       FORTRAN IV
        WRITE (6,100)
 100    FORMAT( 36HREAL PROGRAMMERS DONT USE LOWER CASE)
        STOP
        END
   Cheers,
    Rich S.
No!  Real programmers use GOTO statements!
Keith Cress
There are no GOTO in real Pascal. winky smile
Albert Einstein
Yes.
That's always been a bit of a problem.
ASSIGNED GOTOs are really magic.
Some would say "Black magic".
I came from a Basic back-ground and lived by them buggers.
I keep forgetting to get that book name. So sorry!  I am writing myself a note!
Keith Cress
That is why only real programmer can program in Pascal.
hairpull
Albert Einstein
Keith!
That book has a copyright date of 1996.
And I thought you were old school.  winky smile
Albert Einstein
Ha!  I'm old school but not reeeeally old school.lol
Yeah, why do people name things that exist in a temporally based realm "modern" or "the new" which starts antiquating immediately.lookaround
Sill a good book!
Keith Cress
Real programmers don't comment
If it is hard to write, it should be harder to read
Go on usenet in one of the ebooks groups. I've seen dozens of programming language references posted in in the last month.
I would recommend that you preview the books recommended on this thread aganist the reviews on this website.
http://brian.accu.org/bookreviews/public/index.htm
There are books out there which appears to be excellent, but really just propogate wrong information or is just a re-print of the manual.
cheers,
tyc
