Create mail when cells are filled?
Is there a way to get excel to automaticlly email me when someone in my network fills in 3 or 4 cells? What I am currently doing is Routing a product Change Notice to various people (in my company) and when they close the workbook it routes on to the next person. I am the last one on the list. I would like to send people a link to a location and when everyone has signed it, then it would send me a message. We use Outlook for our Mail.
RE: Create mail when cells are filled?
Private Sub SendEmail(filename As Variant)
Dim aOutlook As Object
Dim aEmail As Object
Dim targetaddress As String
Dim subjectstring As String
Dim hyperlinkstring As String
' communicates with Microsoft Outlook to send notification email
' inserts a hyperlink into the message body for quick file opening
' prevent crash if outlook closed or not available
On Error GoTo errhandler
' limited test on recipient
targetaddress = cmboemailto.Text
If Not (targetaddress Like "*@*") Then
MsgBox ("Invalid EMail Recipient specified, may need to send notice of RFQ finalization manually")
Exit Sub
End If
' strip U:\RFQ FILES\ from filename for subject
subjectstring = Mid(filename, 14)
' create hyperlink, need to strip U:\ from filename, use <> in link since nonalphanumerics and potential spaces
hyperlinkstring = "<\\PMT-PX02.corp.polymicro.com\data\" & Mid(filename, 4) & ">"
Set aOutlook = GetObject(, "Outlook.Application")
Set aEmail = aOutlook.CreateItem(0)
' set importance to normal
aEmail.Importance = 1
' Set Subject
aEmail.Subject = filename & " Fiber RFQ Finalized"
' Set Body for mail
aEmail.Body = "Please note that an RFQ, saved as:" & Chr(13) & Chr(13) & hyperlinkstring & Chr(13) & Chr(13) & "has been finalized. Click on blue hyperlink above to open."
' Set Recipient
aEmail.Recipients.Add targetaddress
' Send Mail
aEmail.Send
' disable error handler
On Error GoTo 0
Exit Sub
errhandler:
MsgBox ("EMailing Error, may need to send notice of RFQ finalization manually (Outlook needs to be Active) " & Chr(13) & Err & ": " & Error(Err))
End Sub
"It's the questions that drive us"
Cheers,
Joerd
