Problem dealing with imported files ...
I have imported a parasolid volume in to ansys that ansys only shows as wireframe. Is it possible to make its areas visible? I can see the area and volume nubmers with aplo and vplo. but it only displays as wireframe.
thanks,
Mphyscontour
RE: Problem dealing with imported files ...
I think you need to change the solid view options in the /facet command, as parasolid import can change this sometimes. Go to:
Utility Menu>PlotCtrls>Style>Solid Model Facets
and change to either "fine" or "normal".
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Thank you! Drej. That solved my problem.
