copying from sketch to drafting
Is it possible to copy a sketch from for example Generative Shape Design into the drafting module?
RE: copying from sketch to drafting
export you geometric set that you want in Drafter as an IGS file (save as). Rename that file with an .IG2 extension this will open in Catia drafting. Copy the newly opened veiw to the desired sheet (Paste)
You may need to dissasmeble a sketch into wire geometry first.
You can also project 3D wireframe into existing views by right clicking, select "Properties", and checking the radio button under the View tab.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
