What are these latches called?
What are these latches called. You find them on heavy duty steel shipping cases (bigger than a trunk, smaller than a car). They have triangular shaped handles and some sort of hook...I believe.
Look at page 10 on this link:
http://www.armormetal.com/military_containers.pdf
In any case, where can I find them?
Also, I'm looking for more links with containers like this one.
Thanks - Barry
Thanks - Barry
RE: What are these latches called?
Check out:
http
Timelord
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
www.borowskiengineering.com
You might also want to check out De-Sta-Co and Southco. Both companies have a broad range of offerings in the latch and clamp areas.
Rich.....
Richard Nornhold, PE
