CPU usage in ANSYS
CPU usage in ANSYS
I have 3.8 GHz processor with 4 GB RAM and SCSI hard drive with 25 GB empty space computer. But when I do CFD analysis in ANSYS It only use 50% of CPU and less than 2 GB RAM. How to make it use most of the available CPU power and RAM. Page file is set at 8 GB.
I will appreciate any help.
Thanks!
Thanks!
RE: CPU usage in ANSYS
I suspect that the solution is paging to temporary files on the HD, which results in only 50% CPU usage. There's only one solution (ok - maybe two...) which is use a 64-bit operating system - either Windows or Linux. Unfortunately, unless your computer is 64-bit capable, this is going to mean new hardware.
Check with your local ASD regarding the availability of 64-bit Flotran in Windows - I use CFX, so I wouldn't know.
Sorry, but your hardware/OS is pretty much max-ed out.
