2D drafting
2D drafting
I wish to use SE16 in 2D mode to make up electrical schematics and other 2D documents. Simple taske like copy baffle me completely. Solid modelling is no problem.
Is there a guide available? Not having much luck with help in this area.
RE: 2D drafting
Try using the 'select tool' but press Ctrl while you drag the object to move it (it will make a copy instead).
Otherwise, the 'move' command with the copy button pressed at the top left will do the job (one click for the starting point, one click for the end point)
Fred
RE: 2D drafting
