Burr problem when cutting tungsten wire
We are manufacturing a burner mount support out of 0.020" tungsten wire.  We are cutting the material off the machine against a quill.  The quill and cutoff tool is made of Tungsten Carbide 10% Cobalt. Once each part is cutoff we are finding a small burr about .003" to .005". We used Tungsten Carbide 15% cobalt and had massive tool wear and we splitting the wire. We are running about 2,500 pcs per hr.  I was wondering if their is a tool steel specially made to cut tungsten wire burr free?  If not I will need to invest in a different cutoff system on our machine which is big $.
RE: Burr problem when cutting tungsten wire
Though not directly involved in the process where we used Tungsten wire I do remember that they had problems with the degree of anneal on the smaller wires.  For our use we wanted a full anneal.  A partially annealed wire should cut better.
Splitting is a inherent defect of the W wire manufacturing process.  You can get wire with a low split count, for lack of words. Check the burr on your cut and see if it's a split in the wire.
Are you using pure W or WK (potassium) wire?
We are using pure W wire which is full annealed. I will check one of the parts to see what type of burr it is.
thanks for the help
Tungsten wire almost always splits when bent or cut, regardless of the degree of anneal - you have to heat it to red heat (900 F or more) before it has any ductility to speak of.  We always cut it with a grinding wheel (Dremel cut off wheel) to avoid splits as much as possible.  W/3Re has a bit more ductility if you need it.
