Does anyone use AutoCAD Electrical for Substion Design?
Hello everyone,
I am working for a power deliver company and we are currently using AutoCAD to create drawings for the wiring schematics and general wiring layouts in our substations. I was browsing the internet and stumble onto AutoCAD electrical but I haven't found a lot of information about it. Does anyone know of a company that uses AutoCAD electrical for their substation designs? I would like to know if this program actually increases productivity and if it works well for substation designs. Some sample drawings would be amazing. Any information would be appreciated.
RE: Does anyone use AutoCAD Electrical for Substion Design?
Speaking about electrical symbols, I can tell that I've seen many different ways to show the same device and many different styles of doing electrical schematics, depending on company, even if there is an effort from ANSI/IEEE or CSA or whatever standards organization rules a piece of land somewhere. So I think you can take a look on what your company has used until now in its drawings and try to be consistent with that. Creating an electronic symbol library it can be an one-time process with some further easy-to-make updates. It also speaks about your company's 'personality'...
The productivity of using electronic files for drawings is obviously greater comparing to the traditional method: changes are done much faster; the drawing can be sent to plotter and you have time to work on another task; no special paper, special pens, etc.; the plotting has the same accuracy as it's shown on your screen; the same drawing can be easily plotted in different paper formats etc. And very important: do not forget to save your work often (once in 5 to 10 minutes hit the 'Save' button) and to save your files on a data CD or magnetic tape or whatever your computer network uses for backup.
However, after I saw the demo, I can say that it was heavily "inspired" by the Rockwell Automation software which creates ladder logics for programs needed by Allen-Bradley PLCs (Programmable Logic Controllers-see www.ab.com). These PLCs are used on large scale in industrial automation.
I don't think I can use this AutoCAD Electrical to design for example a DC Elementary Wiring Diagram for a protective relaying system with, say, a GE Multilin, used in power transmission and distribution area. The way this schematics have to look is not much compatible with the sofware features. But who knows, maybe I'm wrong again...
xnuke
"Do you think you used enough dynamite there, Butch?"
www.altasystems.co.uk.
You can also get trial CD's to try the software out !
There are two versions an ad on for AutoCADor a standalone version that uses the AutoCAD engine.
We've found it very quick and efficient, but like all these systems you need to set it up properly in the first place.
Drawings are saved in its own format or can be exported in .dxf but you loose some of the intelligence behind the objects. We use this option for record drawings that are given to clients.
Hope this is of interest
