How to "fix together" in a sketch?
I've gotten so used to the way that I do business - I need a tip for a new method...
I am doing the dxf/dwg to embossed text method. When I put the letters in a sketch, they come in at a very inconvenient location, so I need to jockey the orientation a bit.
Is there a way (other than constraining numerically) to fix all the components relative to one another, so that they can be easily moved? I want to move the text without anything changing except for the location within the sketch.
It's too much of a hassle to move externally, as reference planes tend to tie the sketch to a family, and then moving with the compass moves things you never wanted moved. (external to the sketch) It's easier just to handle it in the sketch.
Thanks in advance.
Thanks in advance.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
RE: How to "fix together" in a sketch?
Yes, I always do this - but for some reason, it still manages to catch hold of something. (even when I have isolated planes) I mean, if you change support, the idea is still to use the compass to position in in the 2 axes that are not the projection axis, is it not? (which I prefer to do inside the sketch - but I use "positioned" to flip the text)
I don't know if it's a bug, or if I just don't understand the "family" logic.
On the other hand, I can't believe that I didn't see that function. I'm ashamed. Thanks for the help.
Why your stuff seems to "catch hold of something", I'm not sure. You might try checking for implicit constraints. Many times I end up just turning these off, as they are almost impossible to get rid of if CATIA accidentally creates one that I don't want.
Yes, but I like the sketch, because it's a good text "manager". That is, all the curves are self contained, and I can label the whole thing by it's text identity. Join curves force you to do one character at a time.
By the way, as a side note - has anybody noticed how much lighter the models are when you use the original polylines, extract points, and remake the letters with splines, or a series of splines? You can fillet SOOO much easier, without all of the sliver faces caused by polyline faceting.
Do you ever use the snap command (looks like joined 2 spheres)
To adjust component locations. This will move component locations instantly w/o constraint. Snap together planar faces, planes, vetex, point, axis, cs and combinations of many. Quick and easy. M8
If you uncheck "check connexity" the join will join element that don't meet
