Angular Guy Wire Placement
Can anyone tell me if there is a code that governs angular displacement of guy wires in industrial applications?
I seem to recall reading somewhere that 30 degrees is a *minimum* from the vertical at the upper connectors. (*minimum* 60 degrees at the base anchor point).
If this be the case, is there a code that governs these minimums?
Thanks in advance for any assistance.
Thomas
