5H COMPRESSOR MAIN BEARING REMOVAL AND INSERTS
WHAT IS THE PROCEDURE OF REMOVING AND INSERTING THE MAIN AND PUMPEND BEARINGS FOR 5H46 CARLYLE COMPRESSOR . PLS EXPLAIN IN DETAIL, BETTER IF THEREIS ANY PICTURE OF PROCEDURE....AND WHAT TOOL IS USED FOR REMOVAL & INSERTING BEARING, WHERE IT IS AVAILABLE, ALSO ANY WEBSITE TOO SEE IT...PLS HELP.........
RE: 5H COMPRESSOR MAIN BEARING REMOVAL AND INSERTS
It took me less than two minutes to find the application and service manual on the Carlyle Compressor web site.
Here's a hint, see the Google search box at the top of this page?
look at fig 47 and 48 This is the same as a Carrier 5H46
