How to trigger a function in VBA to run???
I've done a set of codes or a function, see below) which will be recalled to to do a simple task.
However, I found the function only "recalculates/runs" when the (contents of) arguments have been chnages "directly". As this function is called and appears in a worksheet where the users cannot work on it, this function never works at all..........
Are there any methods to make it run when the users press "enter" while working on other worksheets??
Thanks!!
'Looking for the dimensions based on the section unders consideration
Function SectionDim(SectionConsidered As Single, Element As String) As Single
    Dim I As Integer, K As Integer, Row_No As Integer
    Dim LowerBound As Single
    Dim Flag As String, Flag_Length As String
    'Assign dimension to the corresponding section under consideration
    With Worksheets("Input_Data")
        Flag_Length = Len(Element)
        For K = 17 To 66
            If Element = .Cells(K, 6).Value Then
                Row_No = K
                Flag_Length = Len(.Cells(Row_No, 6).Value)
            End If
        Next K
        LowerBound = 0
        If Flag_Length = 1 Then
            I = 10
            Do
                If SectionConsidered > LowerBound And SectionConsidered < .Cells(Row_No + 2, I).Value Then
                    SectionDim = .Cells(Row_No, I).Value
                    Exit Do
                Else
                    LowerBound = .Cells(Row_No + 2, I).Value
                    I = I + 1
                End If
            Loop Until I = 109 Or .Cells(Row_No, I).Value = " " Or .Cells(Row_No, I).Value = 0
        Else
            I = 10
            Do
                If SectionConsidered > LowerBound And SectionConsidered < .Cells(Row_No + 1, I).Value Then
                    Exit Do
                Else
                    LowerBound = .Cells(Row + 1, I).Value
                    I = I + 1
                End If
        End If
    End With
End Function
RE: How to trigger a function in VBA to run???
Correction:
Just pressing "Enter" not adding a command button
Steve
